Zeus51
- 36
- 28
- Birmingham, AL
Has anyone used expanding spray foam insulation to close air gaps in the cab? If so, what did you use? Did you spray foam the bottom portions of the driver and passenger side air vents?
I've seen it done. It's not pretty. If you can get enough in there to make a difference, it caves in the inner (lower) skin.The roof metal has a very small cavity between the two metals. There is more space around the edges but most of the center has only about an 1/8 to 3/16 of space. The metal is thin there and foam would probably distort it. Also it would take a lot of holes to get the foam to spread and let the trapped air out.
