- 1,959
- 418
- 68
- Culver City, CA
All right my loyal followers, I am closing in a rear outboard brake drum solution with the help of Brother Glenngineer. It's not all locked down yet.
Be forewarned that the solution will require machining of the drive hub in order for the chosen drum to properly pilot to the hub. Next step is to obtain the drum, machine the hub, then dry assemble for fitment. The studs are also on order. I will divulge all part numbers once I verify that this will work.
Stay tuned...
Stay tuned...
