- 1,118
- 1,243
- Basehor, KS
How many volts do you have on that block when F1 and F2 are connected while the Start switch is being held in Start and do you know roughly of what your rpm is when running?
You indicated that the Genset was running / showing 50Hz with only a few Volts - this would indicate a low rpm
60Hz equates to exactly 1800 RPM
I have 24 volts there. On the block. Only when the start switch is held.
