MEP005A 5volts only
peapvp
1,243
Basehor, KS
Desoldere Q1. I got 167 across both legs. This diode has two legs unlike the others. If I did this right., then it's not blocking properly.
That’s an scr with one leg being the gate and the other two anode and cathode -
pf.hal1984
Killeen Tx
So I take the the threaded portion would be anode or cathode? Either way i get nothing across except by testing both legs. I take it this one is shorted out?
peapvp
1,243
Basehor, KS
Procedure to Test the SCR with the help of Multimeter:
  • To test the SCR, keep the Multimeter into Ohmmeter mode.
  • Connect the positive output lead of the multimeter to the anode and the negative lead to the cathode.
  • The multimeter should indicate no continuity.
  • Touch the gate of the SCR to the anode.
  • The multimeter should indicate continuity through the SCR.
  • When the gate lead is removed from the anode, conduction may stop or continue depending on whether the multimeter is supplying enough current to keep the device above its holding current level.
  • If the multimeter indicates continuity through the SCR before the gate is touched to the anode, it indicates that the SCR is shorted.
  • If the multimeter will not indicate continuity through the SCR after the gate has been touched to the anode, it indicates that the SCR is open.
pf.hal1984
Killeen Tx
JAN2N689 NSN 5961-00-226-8697
peapvp
1,243
Basehor, KS
Btw. did you adjust your Rheostat to 12VAC with T3 connected or did you do that before connecting to T3 - just double checking
peapvp
1,243
Basehor, KS
Only between C and A if G is connected with an extra wire to A while A is on your DMM Plus Lead and C on the Black Lead - you need three hands for this test - G acts like an on off switch when connecting to A
pf.hal1984
Killeen Tx
After
It works as stated by jumping a A and G. But it works both ways because C acts like it is shorted to H. All I'm doing is jumping A to G which is shorted to C. With test leads switched on both sides. There is no blocking when jumped.
peapvp
1,243
Basehor, KS
After
Ok, C and G are like a Diode - however it doesn’t matter - the only two questions which matter for an SCR is that A and C are conducting when G is connected to A and it stops conducting when G is removed from A - this test has to be performed in Ohm setting on DMM not diode test
peapvp
1,243
Basehor, KS
After
A SCR fails only in two ways:
1. It doesn’t turn ON at all
2. It turns on On all the time
It basically looses its ability to act like a switch or relay
pf.hal1984
Killeen Tx
So this
So this Isn't a diode? And yes, it is functioning the way it should as stated in the test. But like I said. C and G are not blocking as you say it acts as a diode. I have continuity both directions between C and G.
peapvp
1,243
Basehor, KS
So this
Yes, these devices work with much higher voltages as your meter and at that point C and G are blocking - they go up to 200 to 1000 VAC between A and C with only a few volts needed on G to turn on
peapvp
1,243
Basehor, KS
You see you got 167 if you had a short then you would get 0 - btw how is Q2? I am on an IPhone and it makes it difficult to jump between posts
peapvp
1,243
Basehor, KS
And SCR’s are AC devices which means they have voltage drop in either direction and in your case it 167 milli Volt
pf.hal1984
Killeen Tx
So what your saying is I need an out
I broke out my power probe and put power and ground to G. It won't switch to allow continuity.
I didn't mean a short. That was my fault. I have to do Q2 tomorrow. What I'm saying is that G
The connection between C and G looks like this here:
I have to do Q2 tomorrow. My wife is getting upset. Lol
