- 142
- 35
- 28
- Los Angeles, CA
I'm noticing that when I park, the drain hose for the stock fuel filter onto the driveway. Is this normal? The drain cap on the fuel filter is tight.
I removed the screw and I didn't see any place for an o-ring. The petcock looked in pretty good shape so I cleaned it off put it back on. It appears to still be draining but I'm not sure it's as bad as before. I'm still not happy with the leak in the driveway but it's not as bad.It may require the entire petcock screw. Report back. Happy Holidays.
Are you sure its leaking at the drain? I just had to replace my housing with a spin on unit as the original was leaking (Bad) from the sensor wire on the back.I removed the screw and I didn't see any place for an o-ring. The petcock looked in pretty good shape so I cleaned it off put it back on. It appears to still be draining but I'm not sure it's as bad as before. I'm still not happy with the leak in the driveway but it's not as bad.
It looks like it's coming from the drain hoses but I'll ensure that's not catching the drips from above.Are you sure its leaking at the drain? I just had to replace my housing with a spin on unit as the original was leaking (Bad) from the sensor wire on the back.
