Sturgis7754
- 4
- 8
- Powhatan, Va.
To use on a 003a gen
Thanks for your reply. I have a MEP -003a old gen. This gen has been setting in a field for, I would guess, 10 years, at least. Not covered or protected . If and when I get the engine to run, I suspect, there will be many problems with the generator, wiring, gauges etc. When you are checking out a gen, does the hook feature become a major asset, considering there are many wires on these Gen sets? It appears that most wires are AC related and the hook feature would let one quickly check for current in each wire. Would you suggest just getting a multimeter? Thank you for your help. Sturgis7754Basic clamp on meter for voltage and current, Klein makes a decent meter. There are cheaper ones out there that will do the job, but Klein is about the minimum brand/quality I would buy for my own personal use.
Klein Tools 400 Amp AC Auto-Ranging Digital Clamp Meter with Temp CL210 - The Home Depot
Klein Tools CL210 is an automatically ranging digital clamp meter that measures AC current via the clamp, AC/DC voltage, resistance and continuity via test-leads, and temperature via a thermocouple probe.www.homedepot.com
Personally I use a Fluke 87-V kit with the i400 clamp in it, but I do generators for a living, for a homeowner it's overkill.
The clamp feature is just to measure the amount of current being used. So for just getting it running, no, it doesn't really matter.Thanks for your reply. I have a MEP -003a old gen. This gen has been setting in a field for, I would guess, 10 years, at least. Not covered or protected . If and when I get the engine to run, I suspect, there will be many problems with the generator, wiring, gauges etc. When you are checking out a gen, does the hook feature become a major asset, considering there are many wires on these Gen sets? It appears that most wires are AC related and the hook feature would let one quickly check for current in each wire. Would you suggest just getting a multimeter? Thank you for your help. Sturgis7754
Most "normal" Meters today, have features that 20-30years ago were beyond my ability to pay for. The first hand held meter that read hertz, that I saw, was just before the first Gulf war. A John Fluke, 8060. Cost $1,200. Or that's what the Army paid. The Grandson of Mr. John Fluke, brought 30 of them over to Germany to be issued to the 32nd AADCOM. My boss, told me to find a good hand held meter to send with all the maintenance units to the war, ASAP! So I picked the 8060. Did not look at the price. The Army bought 30 of them. When Mr Fluke got here, I took him to lunch, and (naturally) beer. He had 3 beers, and out of the goodness of his heart, gave me a meter just to be nice. I used that meter 28 years, and it was always spot on. Then I loaned it to a soldier. Well, had to buy a new meter then.The clamp feature is just to measure the amount of current being used. So for just getting it running, no, it doesn't really matter.
Where it gets used mostly is seeing how much load you are putting on the gen and balancing loads.
Most of the time you're just going to be checking for either voltage or resistance. Voltage to make sure you have enough power going where it's supposed to go, and resistance or continuity to make sure the wire is making the circuit where it is supposed to, and not open or shorted.
A standard multimeter will cover just about everything you need in order to get it up and producing power, except for maybe a few limited issues that aren't very common.
Pretty neat to own one, great you shared it with us. Sturgis7754Old Signal Corps volt ohm meter my wifes grandfather gave me. it works but I prefer my Fluke. View attachment 790079View attachment 790080
