Removing Cab
Berend
72
Netherlands
What is the easiest way to remove the Cab from an LMTV. In a couple of weeks I’m going to swap a cab.
Any tips ?
Thanks
Verzonden vanaf mijn iPhone met Tapatalk
Suprman
685
Stratford/Connecticut
It unbolts at the front pivot there are hex bolts. You have to disconnect the lift arm and all the electrical/air lines. I used straps around the cab and lifted from above.
B-Dog
288
Denver, CO
Considering the existing condition, unbolt everything and tilt it forward until it falls off. Drag it from there....
It's really pretty easy to remove the cab provided you have some way to physically remove it. I removed the fenders and the step/box thing under the door. I made 4 lifting brackets that stuck out the side; 2 bolted to existing threaded holes to the front under the door where the step/box panel attached and 2 on the rear where the fenders attach. I used a gantry crane with a hoist on each side of the cab, a taller crane would've allowed for better lifting angles.
NDT
6,346
Camp Wood/LC, TX
Berend did that 1081 come from a European auction? What year is it? What are those triangular protrusions on the bumper? Never seen those.
Berend
72
Netherlands
Yes came from the EU auctions , the triangles are from the low boy trailer that delivered it
It’s 2008
MGKMartin
23
Portland, OR
The TM's have the entire process. For the junk cab, disconnect everything and just lift off. For the good one you are putting on, make sure you use a spreader bar so you don't crush the rain guards or bend the roof.
NDT
6,346
Camp Wood/LC, TX
Berend if you don’t have a use for the antenna mount on the cab, I have been searching for that for years now. Just the part that slides up and out. It’s missing on my 1081.
chucky
18,868
TN .
If you go on youtube and search hellicool hellipad lmtv cab removal episode on the truck he calls patricia (1078)
Berend
72
Netherlands
I will keep it for you if i'm not going to use it.
  • Like
Reactions: NDT
