aembry1009
- 0
- 1
- Bowling Green, KY
I apologize in advance if this has been previously covered, but I have read countless topics and not found my answer..
I am simply trying to verify that the isolated ground is properly set up before putting power back to everything. Working on M1009 GEN 2 circuit.
Both alternators are installed into the truck. Why do I have reservations? The quality of the work done by POs is the reason and the alternators look to be fresh rebuilds.
I have measured resistance from alternator studs to case and determine that the circuit is closed, but I don't know if that is a proper way to check that the ground is isolated.
