Centramatics?
richingalveston
120
galveston/Texas
I have them on my blazer and I think they are great. I have 1 ton axles so mine would be different model than those for a stock 1009. I have 39 inch tires on 16 inch rims and the centramatics make the tires ride smooth as silk. I can take them off and notice a difference. I do have the tires balanced with weights but that does not work at all speeds. when you hit certain speeds you get some small vibrations with out them. With them on my truck is as smooth as a Cadilac.
I highly recommend them. much better than balance beads.
Curtisje
694
Okinawa, Japan
I use both centramatic and balance masters. Both brands work well. I won't quote a part number here. You need to pick correctly from the manufacturers website for your application.
