Hello.
I appreciate the vast amount of knowledge here on the forum and thank you in advance for your thoughtful input.
I am going to build an overland vehicle from the solid bones of an LMTV.
Most overlanders carry two spares on their adventures. This is because if you blow a tire and have to use your spare, well, then you no longer have a spare. Which is why you carry two.
My thought is to only carry a single spare and count on the run flat inserts to allow me to limp to help in a situation where my spare is no longer in play.
How feasible is this?
Are there downsides to running wheels with the run flat inserts?
Which run flat insert is preferred?
Thanks again for your insight.
