diogenescreosote
- 6
- 3
- Willits, CA
I need to run 6kW of CFL bulbs on an MEP-803A generator. The CFL bulbs are rated for input between 50Hz and 60Hz.
I want to reduce noise, fuel consumption and engine wear. So I was thinking of turning the frequency down to 50Hz, so the engine spins at 1500RPM.
Will doing this actually result in less noise, fuel consumption, or engine wear?
Is there any danger in doing this that I should be aware of?
