m923a2 not airing up
winterton1
24
San Diego, Ca.
the last couple time a started the truck, it took a long time to air up. The last time it would not air up past about 25 and now not at all. I soaped everthing i could with soap but no luck. i replace the governor and did a complete service/rebuild on the air dryer. Still would not air past about 25 . .. i hooked up my compressor to the hands but still only got abot 30. I re-soaped everthing in sight and found a valve leaking on the passanger side tank closest to the air dryer. Could this one valve leaking stop the truck from airing up??? i know it sounds like a dumg ? but with all the air that should be going in i wouldnt think that would do it. Im going to get a new valve , but was just wondering...mike
simp5782
Feo, Fuerte y Formal
9,493
Mason, TN
If both emergency gladhands are close i would start by Spray around the spring brake cans.
simp5782
9,493
Mason, TN
Also check head gasket on compressor damn things blow out.
If the truck wont air up with shop air then it is an issue somewhere else. A check valve at the air dryer prevents back feeding to the compressor
winterton1
24
San Diego, Ca.
I replaced two leaking ball valves, rebuilt air dryer and put a new govenor in, but still no luck. when airing from shop i stll cant get past about 27psi and can now here air escaping the air filter intake stack. Any ideas??
winterton1
24
San Diego, Ca.
i replaced the q2 and quick release valves for good measure along with all of the brake diaphragms. figured i might as well...a few were cracked but nothing to bad. i sill have air escaping the stack and truck wont air up even with the shop compressor. could it be the treadle valve...how would i test it?
simp5782
9,493
Mason, TN
Close the primary tank valve on the wet tank under the truck. Air the truck up from a compressor. See if the secondary takes on air. If it does and the air is not coming from the stack we know its on the primary side. Repeat this test with the secondary valve closed if needed.
Or
On the frame. Behind the air box. Is a valve. Will have a big line or two from the front. One or two small air lines going into it. One big line from it will go up and over the frame. That is how you identify the valve
Remove each air line 1 at a time while the truck has air escaping from the stack. Then post a picture of which air line you removed had the air coming from it.
These are the vents. I can tell you where the issue is from these lines
winterton1
24
San Diego, Ca.
thanks
Or
...thanks ...i will check these thursday when im off.
winterton1
24
San Diego, Ca.
forgive my ignorance...what is the "air Box"...thanks again for the help!
I aired up the truck and both the wet tank and secondary tank charged with air. the primary tank guage onn the dash read 120 and no air was escaping from the stack. the secondary still read 0. i took a pic of the valve i thing you were describing on the drivers side frame. it does have a line that leads from it to the stack... is this the correct valve to check?
simp5782
9,493
Mason, TN
Yes. When you have the air escaping from the stack. Remove one line at a time till you find out which one has air coming out of it. And send me a pic of it and what direction on the truck it goes
Those two lines on the bottom going to the front of the truck. One goes to the Q2 valve. One goes to the lowest connection hose on the brake pedal valve in the engine bay
74M35A2
339
Livonia, MI
It’s the black hose in your first pic.
