- 2,929
- 4,247
- Olympia/WA
(edited) To clear up the confusion, this post is me trying to share the part numbers I found related to the umbilical cable plug in the rear passenger footwell of the heavy variant HMMWVs (M1097, M1123) for anyone that might be looking for them. I found part numbers, and listed them below, as well as links to sites that list having those parts in stock.
Hopefully this helps someone else, as I spent many good hours looking for this plug before finding some with cut off cables on ebay (of which I bought both available, and I don't see any more).
(end edit)
(second edit) Here is a link to a site showing pricing and availability through multiple venders. Part is listed as coming with pins on at least one of the vender sites. This is only for the plug body, not the cable strain relief that attaches to the rear of the plug
(end second edit)
So searching here didn't turn up much, I've been looking for a while for the part numbers for the plug that will attach to the 200 amp umbilical.
Here is the umbilical in question (This part came installed in my M1123, just posting it here for reference.)
I finally managed to find a couple on Ebay, but they had the cables cut off very short, too short to splice the wires I have into it.
Part numbers the seller had listed for the connector were GlenAir #06324, M85049/52-1-32W, MS3417-32A.
The GlenAir number doesn't seem to come up as anything (only real hit was the ebay sale), the other two numbers one shows up as the part below, other doesn't come up as anything in a quick search.
The ones I bought had a part number on them of MS3456W32-1P which brings up this item
(the image they used is generic for the series, not this specific plug)
I don't actually know everything that this particular part number comes with, so I don't know if it has the pins inside of it or not.
For mine I need to order new contact pins, so I disassembled one of the two I bought and took a look at it. Found the pin contact has a color code on it, finally tracked down that code to this part:
It's sized for 2-0 gauge cable.
The cable on the plug and on the BEOD I'm putting this connector on is 1-0 gauge.
To use with 1-0 gauge there is a bushing kit to reduce the size so that it will crimp in properly. (no picture for it)
Here are a couple pics of the ones I bought.
(end edit)
MS3456W32-1P Amphenol - Circular Connectors - Distributors, Price Comparison, and Datasheets | Octopart component search
Find the best pricing for Amphenol MS3456W32-1P by comparing bulk discounts from 3 distributors. Octopart is the world's source for MS3456W32-1P availability, pricing, and technical specs and other electronic parts.
octopart.com
M998 200 AMP UMBILICAL POWER CABLE 12342677, 6150-01-361-8129 NOS
equipmentpartssales.mysimplestore.com
M85049/52-1-32W Amphenol PCD | Connectors, Interconnects | DigiKey
Order today, ships today. M85049/52-1-32W – Olive Drab Connector Cable Clamp 32 from Amphenol PCD. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
