Do you have a parts list and/or another resource telling me more about it?
Here's the parts list:
The Filter:
Donaldson/FBO/DCI P165015 Heavy Duty Replacement Hydraulic Filter Element from Big Filter (Pack of 2 Filters): Amazon.com: Industrial & Scientific
www.amazon.com
Filter status indicator:
Donaldson P171945 HYDRAULIC INDICATOR ASSEMBLY,
VISUAL
P171945
Filter Housing:
Donaldson P762770 HYDRAULIC HOUSING
P762770
The Filter Head:
Donaldson P762766 HEAD ASSEMBLY, HYDRAULIC
P762766
You make your own hydraulic hoses at your local shop.
To the point
@coachgeo made, the concern isn't dirty oil. You should be changing it regularly and keeping it clean. The concern is the HEUI Pump. It's not a matter of "if" it fails, it's a matter of "when" it fails. When it does and the inside grenades, the IFS Kit prevents the shrapnel from torpedoing your injectors. With this setup, the damage is limited to flushing your hydraulic lines and changing the filter. It can be done on the road in 30 minutes, and you're on your way, provided you change the HEUI Pump too.
