Bmd1384
- 1
- 0
- Albuquerque
So let me first state that I have searched extensively for someone with a similar issue and I am no closer to figuring this problem out then when I started.
Also:
Yes, I have read the TM on how to correctly operate the which.
Yes, there is an appropriate shear pin on the PTO shaft.
The issue:
I have a 1971 deuce with a stock winch, which functions properly in all gears (2 fwd, 1 rev). The problem is no matter how hard I try I cannot get the winch spool to freewheel. The in/out handle on the winch moves, however does not move freely as in a broken shaft. This issue concerns me due to the fact that if the PTO clutch gets knocked into gear by accident it may cause some serious damage due to the winch itself always being in gear.
Possible causes:
1. The previous owner used to operate the winch clutch while the PTO was engaged. which according to everything I have read or heard is a BIG no no!
2. I opened up the plug on the passenger side of the winch and it looks like someone had shoved straight axle greases in the winch housing.
Solutions:
I would Really like to be able to fix this with out having to take the winch off of the truck and open it up. So any possible fixes you guys have I would love to hear.
Thanks in advance for everyone's help!
Also:
The issue:
Possible causes:
Solutions:
