1800 Diesel
- 26
- 18
- Santa Rosa County, FL
Greetings to everyone. Been away for a few years, mostly working away from home, but now back for awhile and trying to give some attention to a few languishing MEPs.
For this one, it's 1977 vintage unit showing signs of neglect based on the mixture of sludge/water in the fuel tank. Day tank also had the same junk--resembling a blend of brown gravy and pancake syrup. Also found in the day tank were white "globules" about the size of rice grains--assuming this was a rare species of algae. To get to the question, I spent several hours cleaning the fuel system--all hoses flushed and both tanks cleaned. Predictably, both priming pumps were clogged with the same fuel tank mush. Also had to replace the float switch assembly in the day tank since one switch showed continuity whether up of down. Also, the tube had a 2" long crack from prior maintenance over-tightening the set screws on the collars.
Once all the fuel issues were resolved and the system was primed, I attempted a light-off but the IP produced no high pressure fuel delivery. To troubleshoot, the following steps were taken:
1. Removed the return fuel tee fitting and cleaned. (At this time, left the ball check in place.)
2. Removed the governor cover to inspect/test the stop solenoid. With 24v applied to the terminals, the solenoid would not pull the shutdown arm in. After spending a little time cleaning up the solenoid assembly, it began to function properly.
3. With the cover off I noticed what I believe is the metering valve linkage stuck. With mystery oil I was able to free up this and the connected governor linkage.
4. I reinstalled the solenoid, taking care to verify the shutdown arm assembly was in the correct location. (Not much choice here, as the governor cover plate is positioned by three small bolts.)
5. Removed IP timing cover and gasket and flushed clean fuel through the pump body using 24v pumps. A few specs of "coffee grounds" were seen flowing out.
6. Reinstalled everything, loosened fuel banjo fittings and cylinder #1 & #4 injector line nuts and then attempted cranking.
After seeing fuel flowing from the HP fittings I tightened all loose fittings, cranked again and with much relief, the engine started right up. Speed hunted for about a minute or so but then stabilized and I set the speed for 60hz. The problem showed up when I did a shutdown with the S/R/S switch (32). The engine slowed down, but did not do a "clean" or quick shutdown. I actually had to manually shut the engine down using the shutoff lever on the side of the injection pump. When I did this I could feel an interference or detent on the lever that I had to overcome in order to do the shutdown. Has anyone run into this one? I plan to remove the governor cover again and attempt a new re-install. If this doesn't work, I'll try installing a different solenoid assembly.
