Katavic918
- 54
- 28
- Maryland
After I bypassed fdc on my last deuce, I turned the the fuel down too much and it got to a point where it wouldn't start or idle without giving throttle even when warmed up. Turned it up a few flats and it worked fine. Make sure you install a pyrometer now or soon after you start messing with the fuel adjustment. I agree with you that it doesn't make sense that it would be an adjustment since it just happened a couple months after you made changes to the system. But Its worth a try and you can always go back if it doesn't help.
