sallystrothers
- 13
- 8
- boise, id
I just dropped the pan from my 4 speed to change the fluid (and filter while I'm at it). I'm wondering, is it worth it to add a drain plug to the pan while its out? I've seen a video where a guy drills a hole and welds a nut and I've also seen other products that don't need welding. Next time, should I just disconnect one of the transmission cooler return lines and connect a hose, start it up, and run it until it stops flowing?
