ThatXJGuy
- 0
- 6
- Riverton, Wy
I have a G7117 that I want to keep looking original, but it will be repowered soon with a much more powerful engine and I am wondering about a bunch of things with the axles.
1. How strong are they as far as torque? On one hand these trucks were beasts and could pull anything it seems if you give them enough time, but on the other hand they were pretty low powered especially by today's standards. Im putting in a 6BT Cummins and will have a ton of power in comparison to the original engine. The driveshafts and U joints seem well sized but the slip joints on the driveshafts are like pencils so I'm hoping that there aren't any parts in the axle like that.
2. What axle ratios did the have/offer? I know I can get under there and either pull them all apart and count teeth or spin tires and count revolutions but all of those things are difficult in its current location. I'm about a month or two from bringing it into the shop (hopefully not longer) and I would like to know a bit about them in the planning stages.
3. Parts availability? I crawled under the truck just a couple hours ago and noticed substantial rotational play (backlash) on the rear pinion and I'm not sure whats allowable but it seemed like a lot and got me wondering. Also Hubs, for some reason my truck has 10 lug rear hubs and the original 6 lug hubs on the front. The axle looks original other than the hubs so I'm wondering if somebody just swapped the hubs when something went wrong with the originals or something. Has anybody heard of this before?
4. Brakes. Is there anything weird about these axles that would make it difficult or impossible to do a disk brake conversion? With great horsepower comes great responsibility to make sure it stops. Most axles can be relatively easily converted with weld-on or bolt on caliper brackets and brake disks that will fit. I do know it may be an issue to find disks that will fit the big 6 lug pattern but Im up for that challenge even if it means some machining.
I do have a set of Dually axles from the engine donor truck but I would much rather stay with the originals if that's possible. I don't want this to be a body swap where I really have a dodge truck that looks old. I want my 1942 G7117 to be usable in the modern world. I am planning on keeping MV tires and wheels, original bed and cab and frame, but upgraded mechanicals. I will also be upgrading the suspension and steering, once again with great horsepower...
Before anybody goes bananas on the "keep it original" train: I really wanted to but can't justify finding a transmission to replace the cracked one that's in it, trying to un-seize the engine and hoping its rebuildable, and rebuilding the transfercase which has sloppy shafts on every side, just to have a truck that like most MVs is hard to use on modern roads for modern jobs and at modern speeds. This is my third MV and I love original, but its not in the cards for this one. Its also been very abused and neglected and isn't going to be easy to restore as it is.
I hope this is in the right spot on the forum and I hope you guys have some answers for me. Thanks in advance.
