Page 1135 is the symbols page followed by MANY pages of schematics. What are you seeing? I referred you to volume 3 so that seriesvof pages applies, but if you look in the back of other 20 series manuals you will find electrical schematic s too, as Ron pointed out.
Maybe it would help us help you if you are more specific about what you mean by "failure" specifically what continues to work (like engine running) and what stops working. Be specific.
If the engine still runs then the fuel shutoff solenoid is still powered and that comes from the PDP, via the start inhibit relay, so the PDP HAS power, etc. However, it occurs to me that someone might have made the fuel solenoid modification to power it off the alternator (mods highly complicate group troubleshooting). Where did you get your truck?
Thank you for answering me. I went to the pages in the manual that you stated and yes it is there as you had said. I did not find it in the Table of Contents mentioned anywhere and after leafing through many pages and what I thought was going to the end of the manual, well let's just say I was wrong and you have corrected my error. Thank you
Now the "failure" is power to the transmission for one and the problem with starting is not that it loses power to the starter itself but to the solenoid activation so when you push the button you get the starter momentarily engaging and then stop then momentarily engaging and it repeating as in bump bump bump etc so it is losing constant power. Now after finding components and cleaning cables to them I think I found the problem. When working with the Polarity Protection the 24vdc side was secure but on the 12vdc side it appeared not to be loose but the stud had been hot and changed temper and the nut was bonded to the stud pretty much indicating lots of heat. The lugs themselves indicating the same. The stud twisted off even though penetrating oil and time and working were used. Now that I know that Diodes are in the box then I know that it shouldn't be an intermittent problem, it will either go or no go. I by-passed the Polarity Box and securely fastened the cleaned cables and so far it seems to be working well but being it was an intermittent problem that just started on a proven truck and now we do have brush season here in Florida and the truck is running quite frequently it should prove out pretty fast.
The truck was issued from the State of Florida through the Forestry Division but I have pretty convincing suspicions that the truck was a parts donor truck until someone threw parts on it and reinstated back to service last year.
I plan on using the schematics to see what 12vdc powers and to see what 24vdc powers and I still have the question of power distribution when I actually flip the Master Switch.
So right now I am running and will let y'all know how the story goes in a couple of weeks.
I truly appreciate the assistance of all who helped me and the "Steel Soldiers" website that I have colleagues and gear heads to go to for my mechanical consoling and parts chasing.
Lugnuts
