MEP-803A replacement gauges and other items
DieselIron
34
13
Nashville, TN
The latest MEP-803 in the shop is now up and running.
This one was interesting as I found a large wet, stinky rodent nest up on the Generator terminal strip! Yuch!
Much bleach and cleaning finally got that area clean again.
The next item addressed was the engine fuel stop lever, it was broken in two!
My solution was to use an aluminum plate bent around the arm and JB Weld with a screw to hold it together.
I tested by activating the solenoid at least fifty times with no problems.
60659842459__E53BA696-24EB-46B5-836F-CBF0ED7315C4.JPG 60659844115__453FB95A-09D8-4E67-AE86-72F2E9E24C6E.JPG
Next, I need to replace the fuel level gauge as well as the oil pressure gauge. Tested both and the gauges are bad.
If you know of any replacement gauges please post them here.
Found a VDO "A2C53412988-S "12/24v 33-240 ohm gauge that looks like it will work for the fuel level gauge,
and a VDO "A2C53412998-S" for the oil pressure gauge.
I also need to come up with a replacement fault reset switch for the fault panel. Troubleshooting a test low oil pressure fault was not tripping K12, so tracked it down to the fault circuit.
I opened the fault panel and found the switch was in many pieces! Obviously someone used a hammer on it as some time! :oops:
Thanks for any sources you might know of.
Light in the Dark
5,650
MA
I've got a fault panel available from an 802. Cant do much right now to have it go anywhere, but maybe we can talk down the line if you still need it.
