Floridianson
- 2,511
- Interlachen Fl.
I do not know why I thought you we going in all the way to the axle seal. Run Forest run.
Yes, put some kind of grease on the splines, preferably new. GAA is a lithium complex grease. I think you said that the grease you're using is also lithium complex, so you should be fine.Maybe because Ajax MD started this thread on the same topic, and he was talking about the axle seals and knuckle.
Should I just put some of the old grease over the spines and leave it at that then?
How to make me nervous. No way I can check what the previous owner used, just have to hope that polyurea grease at that time (2000-2009) was more expensive, or they did not had it there, or they did not do anything and the last time somebody did something was in the depot or or or AAAAHGGGGGHHHH.My reading seems to indicate that colors are often a branding thing.
Lithium complex is compatible with many other types of grease but not (for example) polyurea based grease such as Lucas X-tra Heavy Duty grease.
Here's a compatibility chart for your reference:
Grease Compatibility Chart and Reference Guide
When it comes to lubrication in industrial plants, most maintenance people strive for consistency – the use of the same products over a long period of time. This generally allows for smooth...www.machinerylubrication.com
Trying to get myself set up with tools for my M813 maintenance list. Thanks for any help or pointers.Ajax
I'll give my thumbs up as well for the torque multipliers.
I picked up a "not so expensive" one from Amazon in preparation even before I got my 923.
After having all 10 wheels off at least once (a couple more than once already to replace axle seals unfortunately) I believe these things are God's gift to MV owners. Unbelievably effortless to use and so simple and effective.
I also recommend always having a couple appropriate spare lug nuts and studs (RH & LH) on hand before starting anything requiring removing the wheels. I found several lugs and studs on mine that were damaged, cross-threaded, stripped, etc. and needed immediate replacement and many more that had seen much better days and will need to be replaced eventually.
Nothing more frustrating than trying to get your truck back together and on the road after dealing with a failed seal or something and not having a simple spare stud/nut to complete the job, especially as I do most work on my truck on the weekends when the local truck parts shops are not open.View attachment 782281
Sent from my SM-T580 using Tapatalk
The outer lug nut and inner thimble socket is a common item at napa, northern tool, truck parts places. Just call it a budd socketTrying to get myself set up with tools for my M813 maintenance list. Thanks for any help or pointers.
Did the 38mm socket fit the 1 1/2 (38.1mm) wheel nuts?
I am guessing you purchased this part...
What did you do to get the square nut/sleeve style lug off? Did you already have one of the combination lug nut removers like Bigmike is out of stock on?
1-1/2
LUG NUT SOCKET FOR MILITARY 2.5 TON AND 5 TON TRUCKS, AND ANY OTHER TRUCK USING 1-1/12" LUG NUTS. 3/4" DRIVE. USE THIS SOCKET ON SINGLE WHEEL LUG NUTS OR ON THE OUTER NUTS FOR DUAL WHEELS. WE ALSO STOCK THE 13/16" SQUARE SOCKET FOR THE INNER NUTS.www.bigmikesmotorpool.com
