HDN
- 5,087
- Finger Lakes Region, NY
This is an engine question in general, although any information regarding the Cat 3116 specifically is welcome.
The TM for my truck says that the engine should be at an operating temperature of 160 degrees before applying a heavy load. On a 40 degree day, this takes a half-hour at 1200 RPM to achieve. So I'm wondering:
1) Is this a typical warmup time for an engine? On the older gasser army trucks I've driven in the past, i let the engine idle just for about 5 minutes to let the oil circulate and the pistons expand a little bit before going down the road.
2) 1200 RPM is allowed for my truck's warmup even though idle is about 800 RPM. Is there any harm idling at 1500 or 1800 RPM at idle before reaching operating temperature since no load is being applied? This is important to me because I currently need to manually inflate the tires, which takes me about 30 minutes to do at 1100 RPM.
