- 1,579
- 543
- Greenback, TN
I rebuilt the cab suspension yoke in an LMTV. Both bags are replaced and shocks and bushings checked. Did the cab latch seals too. You can work on each side individually in place, or try taking out the whole yoke instead of negotiating those hard-to-get-to bolts on the tops of the canisters. Lifted the whole thing out with the hoist as shown. The four bottom bolts on each side are easy to get. Unscrew the hydraulic hose on the cab latch. The air tubes have to be taken loose either way you remove a canister. There are 3 small screws with hose clamps that need to come off the yoke too..
