WildernessJeep
- 89
- 28
- Huntsville, Texas
So I've used the crane a bit, and it's fantastic! The first few times I used the crane I was working on the throttle linkage (disconnected), so I shifted it at an idle in neutral and manually turned up the throttle to about 1500 rpm's on the fuel pump. I've now reconnected the throttle linkage and when I engage the crane lever (behind the seat) it sticks really bad, and when it finally engages the engine revs up to the governor and stays there. I watched the Youtube video about the crane operation, and he used the dash throttle to set the RPM's (it wasn't automatic). I'm not entirely sure I reconnected the throttle linkage correctly. I'd rather not run it at governor the entire time I run the crane because it seems like unnecessary wear on this old truck, it's really loud, and it makes the crane act like a psycho with super-sensitive controls. What am I doing wrong?
