The torque valves are scarce and reflected in the price if you can find one.
I introduced a significant amount of air tool oil into the air side with
front of the truck on jack stands. Turning the wheels back and forth.
I started with nothing but now have something. I also oil, regularly, through
the air intake side of the valve. I have read, here, that a member was successful at
disassembling and rebuilding the valve. It appears, to me, that they are designed to
be difficult to repair. Be sure to buypass the inline regulator on the air side supply line.
I'd be tempted to remove and completely immerse the valve in air tool oil and supply air
while on the bench to see if you can restore the valve. Mine was slow to respond but
over time it got better.
Be well
