Rubberized paint spray - select interior places
36
13
boise, id
I was wondering if anyone has used rattle can rubberized spray paint on the interior? Right now, I'm only considering it for spraying the bottom of the battery den to keep wear/corrosion down. I'm mostly curious how well it adheres to unprimed carc paint over a long period of time?
Brutacus
201
Marion, AR.
I've used the flex seal rubber spay coating for my battery hold-down. I sprayed mine over an acid etch marine primer, so far so good. If you use flex seal, just be sure to tape everything off due to how messy it is. You might consider the brush on version if you want something more like a molded rubber mat.
  • Like
Reactions: 98G
36
13
boise, id
Thanks, I was thinking about flex seal. Sounds like the brush on version may be better given the right space
US6x4
2,185
Wenatchee, WA
I really like the 3M brand rubberized undercoating and the stuff I got at the automotive paint store was way better than the 3M stuff I got at NAPA or box stores. This stuff hardened a lot more and would resist a thumb nail imprint unlike the other stuff where the thumb imprint never went away.
ramdough
1,729
Austin, Texas
What was it called?
Thanks!
US6x4
2,185
Wenatchee, WA
What was it called?
Thanks!
The napa 3M stuff was 08883 Underseal Rubberized Undercoating
The better stuff might be the 03584 Professional Grade Rubberized Undercoating
Currently I'm using 08882 Underseal Undercoating Paintable and it's working very well. The paint adheres to it nicely.
