I was thinking that it would have to be thicker than that?I did that for my 004. I used exhaust pipe wrap.
Sent from my SM-G950U using Tapatalk
looking at having something heavy enough to stop the majority of the heat.I did 2 passes. Are you trying to provide incidental contact protection? Or something heavier?
That’s exactly the type I was looking for. Also I just learned that you have to wrap the mineral wool pipe insulation in aluminum tube that McMaster sells to match. That’s the only way I have found it being done professionally. Here’s a pic for example of what Im looking for. Anyone use any other company’s?If it is a straight run, you could use preformed mineral wool insulation like this https://www.mcmaster.com/insulation/pipe-insulation-3/mineral-wool-pipe-insulation/ . Otherwise two or three layers of the wrap as recommended by Scoobyshep should work. Just make sure the material is good for over 750 deg. F.
