tardy_pizza
- 2
- 3
- Tucson, Arizona
Aah.. good call.Hydroboost brake system leak @ the pushrod?
I’m starting to think that’s what it is. Have to take a look at it in the morning.Hydroboost brake system leak @ the pushrod? Should be easy to peek under dash & push on the brake pedal & watch for leakage. (wear safety glasses pls)
Not that I could see.Previous owner left an oil pressure gauge line back in there?
Do you replace the whole unit or just take it off the firewall and do the rear seal?Replace it. The replacement comes with a Lifetime Warranty.
replace the whole thing. Its not expensiveDo you replace the whole unit or just take it off the firewall and do the rear seal?
Well I’m out here tearing the bezel apart thinking I’d clean the oil off of everything. Looks to be the speedometer cable.replace the whole thing. Its not expensive
