WTEC II vs WTEC III?
coachgeo
3,461
North of Cincy OH
also believe the wtechIII's computer is below the power distribution panel/behind passenger kick panel where in the wtechII it is under the keypad. Not sure how easy it is to peer in either location to evaluate.... nor what it would look like if you did.
Ronmar
7,451
Port angeles wa
Couple of 10mm bolts to pull the passenger kick panel. If you have a vehicle interface module there, you have a II. on the III, the trans controller is where the VIM usually is...
Ronmar
7,451
Port angeles wa
on a WTEC II the controller is below the keypad and the VIM is below the PDP behind the passenger kickpanel. On a WTEC III the Trans controller is below the PDP behind passenger kickpanel where the VIM used to be and they did away with the VIM. There are a couple of standalone relays for neutral start and PTO/winch function that used to be handled by the VIM relays...
Bric314
Virginia
Is a WTEC 2 truck upgradeable to run with a WTEC 3 selector and PDP without the VIM? Or will I still need of a VIM?
Thanks
DREDnot
443
Phoenix, AZ
Thanks
My understanding is no. When I was trying to get a WTEC2 truck running, The info I was getting was that the control pad, the VIM, and the trans had to all be the same. The WTEC3 truck I'm working on now is way different. It seems like each iteration of WTEC controller have completely different black boxes and harnesses and connectors from one another and they must match the trans it has. Someone more knowledgeable may be able to tell you differnt, but this is what I've seemed to see with my limited dealing with this subject
wheelspinner
1,521
North Carolina - FINALLY !
There is a crossover reference matrix in the TM. I don’t remember exactly where I saw it but it’s there. If I get a chance this weekend I’ll look if no one has it by then.
MrMikey4026
417
Eatonville Washington
I know if the Army puts a WTEC3 transmission in your WTEC2 truck, you get to remove the valve body and replace the transmission harness.
Supposedly there was an inline harness adapter that came with the new transmissions, nobody could find one however.
It was not any fun!
coachgeo
3,461
North of Cincy OH
It was not any fun!
can you be more specific about "not fun" what was difficult about it?? the pull apart is a PITA.... getting the swamped in harness to sit right without getting pinched was pita orrr???
Much appreciate in advance any additional input you can offer
MrMikey4026
417
You have to remove the front driveline and exhaust. Some of the pan bolts are almost inaccessible and there is not enough room to remove them. Not enough clearance between them and the transfer case.
It is very heavy and has to be angled to drop it off. Once off the harness is easily replaced. Putting it back on is worse. I tied the unremoveable bolts to the pan rail with rubber bands, then cut them once the pan/valve body was set into place.
I tore the gasket the first time and got to do it over. You need two people to put it back.
A jack will not work to lift it. Keep in mind the pan/valve assembly weighs in the neighborhood of 90 lbs, the solenoids are easily broken during the process as there is just enough clearnece to get it in and out. The solenoid I broke is military only and expensive.
Mike
coachgeo
3,461
North of Cincy OH
Mike
woud it be less PITA if bed was removed first?
MrMikey4026
417
You have to remove the front d riveline and exhaust. Some of the pan bolts are almost inaccessible and there is not enough room to remove them. Not enough clearance between them and the transfer case.
Mike
MrMikey4026
417
Removing the bed would make no difference.
The computer will have to be reset to remove the learned transmission using Allison DOC to learn the new transmission shifting habits. Remember the WTEC2 has paper clutches and the WTEC3 uses Kevlar clutch material. It has completely different shift characteristics.
I had to change the diagnostic connector to connect to my computer. All the trucks that used the WTEC2 had only the transmission on the diagnostic connector.
MrMikey4026
417
Drat
Assuming Kevlar is better; if one is in an A0 tranny for some reason.. Can the Kevlar type be swapped in while they are in there?
To upgrade to Kevlar, the entire transmission would have to be dismantled and reassembled. I am no Allison transmission expert, there is a possibility that there are also differences in the valve body.
Not worth doing in my opinion.
Mike
