Rear flap tie down failures
warcow105
Lincoln Park, NJ
A little over a year ago I bought a 4 door conversion straight from Breton. Now 3 of the 4 tie downs for the rear flap had the spring fail and can't be tightened. Has anyone else experienced this? Seems pretty bad quality for military use parts.
Michael
DREDnot
447
Phoenix, AZ
Yes. Especially the ones that are all plastic. Brought to you by the lowest bidder...at the insistence of you the taxpayer.
Im assuming you are talking about these POS things...
osteo16
594
Evansville, IN
Hmmm.... those appear to be very much alike/functioning as a “cinching tie down”. Bet you could make these work possibly .. 18DA0807-B25E-486A-8F76-9B3825FF213F.jpeg
Retiredwarhorses
4,447
Brentwood, Calif
These have been failing since GMA had the market...I think they source them, because I’ve had both style, one version is literally garbage. I had an NOS M1102 top and everyone of them broke on the first try....luckily I had a bunch of old ones
that are better, I remove them from old tops I’m throwing away.
DREDnot
447
Phoenix, AZ
Who ever designed these things was a psychopath.
Hard to use new. Need two hands to loosen when soiled. Break easily. It has more modes of failure than moving parts....which is quite an accomplishment in itself. And the strap is usually to wide to go through the stupid "thing" on the body and too short to tie off if it did fit.
Retiredwarhorses
4,447
Brentwood, Calif
thats because the end is folded over and sewn so they don’t fall off....they fit, just have to work it, I’ve replaced many.
DREDnot
447
Phoenix, AZ
I was talking about if you broke a hook and didn't have a good one to replace it, you cant just use the bare strap to tie through the body loop as a field expedient
Bulldogger
698
Quantico VA
They are called Ancra Buckles. I bought a bag of NOS mil spec ones from an eBay vendor but they're so flimsy I haven't bothered to install them.
I am not aware of a source for metal versions.
Bulldogger
DREDnot
447
Phoenix, AZ
Bulldogger
That makes sense. Years ago, Ancra made the best motorcycle tie down straps with that kind of tensioner lock. I still have a set thats nearly 35 years old and still in better shape than much newer knockoffs.
These buckles are a sad perversion of their good name.
Ive never seen a full metal military buckle. Just the plastic body with a metal lever (old style) and the all plastic ones with the plastic lock lever.
