- 8,489
- 2,635
- Monrovia, Ca.
No, you WANT low silicate. If you use coolant that is not low silicate, you get silicate drop out which makes water pump seals leak and causes mud in the system and can plug a radiator. Try and avoid red, orange, pink ELC. The rubber components in the old engines, including liner o-rings, do not like it. The rubber swells and deteriorates causing coolant leaks at the water rail, oil cooler bundle o-rings, the liner o-rings, etc. Liner o-rings that go away equals coolant in the oil and the OC bundle o-rings equal oil in the coolant. Also, keep in mind, the afore mentioned colored ELCs do not like to mix with themselves and especially glycol based coolants. Glycol and ELC will turn black and turn to a thin jelly like and is damm near impossible to get out once it turns. HOWEVER, Cummins does make a coolant that is glycol based AND an ELC and, it will mix with all other coolants, it turns dark, but does not gel. It ain't cheap either, I think it was around $30. a gallon for concentrate. It comes in concentrate and 50/50 mix. And you want the ES stuff.
Hybrid (Fleetcool EX™ & ES Compleat™) | Cummins Filtration
ES Compleat and Fleetcool EX use both conventional and organic additive technology to provide superior engine protection, extend service intervals, and simplified maintenance programs. When properly maintained, ES Compleat and Fleetcool EX are Life-of-the-Engine, 1,000,000-mile coolants.
www.cumminsfiltration.com
