- 1,813
- 1,518
- Orlando, FL
When I first start my engine, it generally starts within a few revolutions, runs for ~5 seconds, then dies. It then requires ~20 seconds of cranking before it will start back up, after which it will run fine.
To me, this sounds like initially it's starting using whatever fuel is in the lines/passages close to the engine (e.g. in the injectors already), but once it consumes that there isn't more and stalls. That would mean the actual fuel lines from the tank, to the water separator, and to the engine, are empty. Once you crank some more, it draws fresh fuel into those lines and can run again.
Sound about right? Where to start looking? Any tricks on how to tell if it's the primer on the fuel/water separator that is bad, or the lines themselves?
Thanks!
Thanks!
