badgerd
Electronic Jedi
- 102
- 65
- 28
- Chesapeake VA
This has been an issue for a couple months on my 87 998 with 6.2. Started with "fan will not come on" but wasn't overheating. I used the TM to troubleshoot the fan (as that's what I thought it was):
1. Pulled fan switch, boil tested and opens around 215. When disconnected, fan operates.
2. Disconnect TDM from Cadillac valve, fan operates.
3. Pulled thermo, pop test showed stuck open. THIS HAS TO BE MY PROBLEM.
4. Replace with new OEM. Fan doesn't come on but wasn't running much for a couple weeks... Hot day take it for a 14 mile run at 55, no fan, thermo housing at 175 when stopped. Ran it home a couple hours later, 180.
5. Pulled thermo and tested, stuck open. Ordered replacement.
6. Received replacement, pop tested, opens in the 195 by my thermometer. Installed after a system flush and new hoses.
After all that, I still can't get it to go over 180 (not the guage, no touch thermometer), that means no fan. My concern is what else am I missing to get this thing to keep a "normal" 190-210 temp? The truck runs fine with good power.
I am totally lost. Not a HUGE deal that the fan never comes on (but tests that it should), but I'm never getting to temp no matter what the magical temperature guesser on the dash thinks.
