Will these wheels fit my M105 trailer
gringeltaube
Staff Member
2,458
Montevideo/Uruguay
Will 16" steel wheels made for the m119 howitzer fit on my M105 trailer? Link to the wheels below.
Yes, if the backspace is 6" or less.
Edit to add: Make sure you have this style of hub on your axle: 2016-07-09 16.49.52.jpg
If you had this other style: 20200507_203920.jpg, then the pilot hole of those wheels in question will have to be enlarged.
gringeltaube
Staff Member
2,458
Montevideo/Uruguay
If you mean those Isuzu NPR wheels like shown at the bottom of that iink/page, the pilot hole is correct (Ø 6.457") but the problem is their backspace being way over 6" (probably more like 8-9" since they are designed for dual rear wheel configuration).
Any 16"-wheel with more than 6 inches of backspace will make the rim hit the drum before the center disc contacts the hub.
Offgrdfam
Massachusetts
Thank you. I have a lot to learn about this thing! I read on another post that 19.5 budd wheels will fit. Does that hold true with this type of hub my trailer has?
