My rear window crank broke and the window is about 1" down from all the way closed (up). Long ago I replaced the handle/crank assembly but now I can't figure out how to get in there. I removed the panel off on the inside. I still have the key and the lock still turns. I assume the clutch broke. I think I can see one of the bolts that goes to the crank handle (driver side) but the other bolt is behind something.
Normally what position does the window need to be in to remove the crank assembly?
Is there anyway to raise or lower the window from the inside of the truck?
My main goal is to get the window closed to keep the yellow jackets out.
Should I just drill out the lock and or crank handle assembly?
