- 3,581
- 3,488
- Brooklyn, NY
How many amps do the glow plugs pull at full load? All 8 together in Winter, worst case scenario?
Thanks,
T
Thanks,
T
When the key is turned on and the wait light comes on the system starts pulling 12 volts at 126 amps. As the cycle continues the amps steadily drop down to 88 amps when the cycle ends and the wait light goes out. With the wait light out the rest of the system is pulling 5 amps.
I measured this with a 400 amp meter. My glow plug system draws from a 24v to 12v converter, not the stock resistor bank.
I live in the desert so the temperature wasn't as low as your asking. It was 40-50 here when I tested them. The system went through the full cycle.
