I noticed the other day that the drivers side while driving was a *lot* more "exhausty" than the passenger side.
I rigged up a plastic bottle with an air fitting and pressurized the exhaust system with 5psi. Had a moderate exhaust leak at the drivers side exhaust header + flange connector with some noticeable soot.
Purchased a new set of gasket donuts (I *think* this will fit "Fel-Pro 60556") and plan on swapping it + the spring bolts.
Just a heads up, these exhaust gaskets are over 30 years old now... might be time to swap them if you haven't yet
