- 434
- 206
- 43
- Lynchburg, VA
Considering putting LED headlights in my M35A3 and thought I ask folks if they had any that they particularly liked and why? Beam pattern? Cut-offs (to not blind oncoming traffic), ...? Thanks!
What are cut offs? The thing I don’t like about LED headlights in general is they too bright. When you consider how high off the ground our headlights are, I would not want to be in a car in front of me or in on-coming traffic. Do cut offs somehow dim them down some?
Bingo! And thank you! I'll go grab a set now!After that expensive experiment...
cattlerepairman, is your lighting converted to 12 volt, or are those LEDs 24v capable?I have gone through two sets of TruckLite milspec LED headlights where one always died after a while, usually losing low beam on one side. Apparently, they have issues with bad solder joints and they are next to impossible to fix because everything is encased in rock hard potting.
After that expensive experiment I simply ordered a set of cheap (70 bucks per light) 7" LED headlights for a Jeep Wrangler off eBay. I bought two headlight harnesses off Amazon for the new headlights to plug into, cut the civy connectors off and replaced with Packard military connectors to plug into the truck.
Had them on the truck since 2018 now and could not be happier. Good light, they work, no issues, plunked right in as if they belonged.
I do not want to get into trouble with moderators or be virtually placed against an imaginary wall and electronically shot, so no eBay link. However, one can go on eBay and search for
US 7'' Round 120W CREE LED Headlight Hi/Lo Beam for 97-18 Jeep JK TJ LJ Wrangler
Damn that thing is Beast.JB audio 12/24v
Hi, Did you wire up the DRL lights on yours?Ebay $45/set cheapies. 12V/24V. They have worked great and actually put out a lot of useful light in a good pattern. Aiming them properly will avoid blinding others as much as possible.
View attachment 800040View attachment 800041
DRLs, wow, nice!Hi, Did you wire up the DRL lights on yours?
I bought the ones likes you pictured at the top of that image. Saw the ones at the bottom too. Neither one is anything like stock any more, so I guess it was just down to personal preference. If I still was around rockcrawlers, I'd be buying the bottom ones though, for sure!Cool beans, so many choices! Anyone have opinions, or experience with both the 4 main ledView attachment 800126 or 15 led type? View attachment 800127
Yeh, been over 5 years since I researched jeep lights, and don’t remember anything except high dollar LEDs. Some have DRL and TS options as wellDRLs, wow, nice!
Can you elaborate on this, just a more appealing look for the rock crawler crowd?...If I still was around rockcrawlers, I'd be buying the bottom ones though, for sure!
those multi-led options are just busier than I personally would care for on my M35, but that's just personal preference. the rock crawler crowd, at least in my experience, tends to go for more bling: more stainless/chrome/fancy setups.Can you elaborate on this, just a more appealing look for the rock crawler crowd?
Hi Murph360Hi, Did you wire up the DRL lights on yours?
You can also buy 7" headlights with clear or faceted lenses to retain the "stock" look for your truck but have replaceable LED bulbs. You get the best of both - original look and LED light performance. But make sure you get a set actually designed and engineered for LED's...not a garage swap from incandescent bulbs to LED's that will just spray light everywhere except where you want it.I bought the ones likes you pictured at the top of that image. Saw the ones at the bottom too. Neither one is anything like stock any more, so I guess it was just down to personal preference. If I still was around rockcrawlers, I'd be buying the bottom ones though, for sure!
Fully agree. DOT has lost that battle. Just doing my bit to ensure it doesn't give our trucks a bad name to be able to see and be (safely) seen at night.You cannot always just replace a regular bulb with an LED bulb in a headlight assembly one-for-one. LED bulb outputs and patterns can be significantly different from standard bulbs and headlight reflectors and lenses need to be designed accordingly for them.
