HeisenBob
- 31
- 28
- Norman, OK
I know this has been covered but I couldn't find the answer to my specific issue. My speedo and odometer aren't working. I unplugged where they conned to the transfer case and used a drill to confirm that the speedo works. Next, I pulled the gear from the transfer case and took it apart. It had old grease in it and was pretty gummed up so I cleaned it, greased it, and put it back together. Next, after inspecting the plastic gear, it's either too big for the square shaft that it drives or it's the wrong size. The yellow gear will fit over the square shaft but it will free spin and the square shaft doesn't spin. Can someone please take a look and let me know if this set up looks correct. If so, I either need a new gear or the shaft is wrong. Thanks for your help.
Robert
Robert
