Yeah I've found plenty of off-brand stuff. Those Goodyears would have been nice
Good looking wheels, Where did you get those?Replaced some tie rod ends with some Moog units. Part #s ES423L and ES423R
Went to aluminum steer wheels and some Goodyear G296 445 65 22.5s. Should last a lot longer than the 395s. 16oz of beads per tire for balancing as well.
Junkyard in Kentucky. Changed em black with krylonGood looking wheels, Where did you get those?
Love the junkyards.Junkyard in Kentucky. Changed em black with krylon
One mans trash is definitely another mans treasure. Heck, all of us have something that "Uncle" thought was trash - and we treasure it for sure!Love the junkyards.
Wes, I know that you run the roads in the winter too... Will that auto drain on the wet tank need a heater as the weather gets colder? Or is that just not something just not worthy of consideration most of the time - considering the part of the country we live in?Fixed the air conditioner today. Blower unit was out of alignment so I didn't have alot of air pressure. Seems to be better now. Foam cleaned the evaporator.
Installed rubber stall mat on the floor and firewall to break some of the heat.
Installed an auto drain on the wet tank.
I always run the heated Dv2 valvesWes, I know that you run the roads in the winter too... Will that auto drain on the wet tank need a heater as the weather gets colder? Or is that just not something just not worthy of consideration most of the time - considering the part of the country we live in?
Did you fasten down at all, or does it work fine just laying it in?Installed rubber stall mat on the floor and firewall to break some of the heat.
Has anti slip bubbles on the bottom. Just lays thereDid you fasten down at all, or does it work fine just laying it in?
Neat. Nice to know - and now I know what to search forI always run the heated Dv2 valves
24v unit is 284817NNeat. Nice to know - and now I know what to search forThanks!
Where can I acquire same materiel for floorboards of my M35?Has anti slip bubbles on the bottom. Just lays there
