- 312
- 234
- 43
- Myakka City, FL
Gentlemen: I think I really have searched thoroughly for the map for the pin locations on the wiring connections for the transmission on the M1078/ 1997/ Now specifically the one I need is the round quick connect just to the right side rear of the transmission. Allison provides the one for the rectangle one located in the transmission and the GI Tech Manual supplies the one for the TCM and then the one on the front through hull J19 but try if I will I can't seem to locate the one by the transmission. The main reason for this is I have lost signal for the C3 Pressure Switch and I want to diagnose exact location of failure. I know I can use different methods of locating them if I have to but I would like to first turn to y'all to see first if I can get what it is suppose to be by design.
Thank you, Lugnuts
Thank you, Lugnuts
