- 890
- 158
- 43
- Las Vegas Nevada
Has anyone attempted to put a spicer 3053a transmission and match it to a OA-331 gasser and got more speed because of the OD transmission?
What are the pros and cons?
Yes this is no problemThis gasser owner is also curious about the transmission swap.
But I'll up the annie and ask if anyone knows if an air shift transfer case can be installed behind the OA- 331 ??
Exactly. I have done it - and promptly switched back to the 3052...The gas engine will not have enough Torque/Power to make the overdrive gear deliver the results you are looking for...
Sure... but not at the same rpms!The torque specs are almost the same and hp just a little less with gas
