- 1,506
- 1,174
- TN
Totally different suspension, so likely yes.Does the cab of the Steyr sit higher than the Fmtvs? I seen a video of a build and it looks like there are risers from the frame at the tilt/pivot points.
actually don't think they sit higher... they just have no cab suspension (or little to none?).... thus why you see risers. The risers hold up the cab essentially replacing our air bags with a riser holding cab at the upper limit? where on ours the bags hold up the cab and limit its updown travel while offering suspension ride along the way For the 12m18 (our direct cousin you could say) There is a kit sold by the premier fab/upgrade company for 12m18's to change risers to coil over shocks instead.Totally different suspension, so likely yes.
They do have a cab suspension.actually don't think they sit higher... they just have no cab suspension (or little to none?).... thus why you see risers. The risers hold up the cab essentially replacing our air bags with a riser holding cab at the upper limit? where on ours the bags hold up the cab and limit its updown travel while offering suspension ride along the way For the 12m18 (our direct cousin you could say) There is a kit sold by the premier fab/upgrade company for 12m18's to change risers to coil over shocks instead.
Fahrerhausdämpfer - EXCAP
excap.de
thanks.... could not remember if they had "none at all"....... or the guys who have them were saying " they might as well "have none at all" cause the ride is stiff and rigid. Many add air ride seats cause the ride is pretty uncomfortable for an expedition truck.They do have a cab suspension.
different chassis / small similarities. our riser has rubber bits in it. might look that tall w/out bumper too...Are the frames the same?
A review of the specs shows that it IS in fact taller.actually don't think they sit higher... they just have no cab suspension (or little to none?).... thus why you see risers. The risers hold up the cab essentially replacing our air bags with a riser holding cab at the upper limit? where on ours the bags hold up the cab and limit its updown travel while offering suspension ride along the way For the 12m18 (our direct cousin you could say) There is a kit sold by the premier fab/upgrade company for 12m18's to change risers to coil over shocks instead.
excap.de
good question would be ride height vs sitting height?. Ours tend to sit lower till the rear bags inflate after start up. Are tires used same dimensions? That might make overall height different tooI review of the specs shows that it IS in fact taller.
no sure what you are asking..... site for Steyr or site for FMTV's? If Steyr..... you might want to ask that on a Steyr discussion board. Your probably better off having what you want fabbed for increased cab height... Looks conceptually simple; but in reality may end up very complex. (will the whole wire harness need to be 2" -3" longer for example... so it is not stressed???) While at it have them fab in mounts for rear half of front fender you would like to fit and get only that from a steyr vendor?Did a little digging on the specs. Looks like the 12m18 cab sits 15" taller. At 10' 5". The springs being taller and potential cab mounted higher I believe.
I like the extra clearance for the front tire, and I like the rear part of the front fenders.
Is there a common source for parts, other than ebay? Like a direct site?
Yea, was referring to Steyr parts, cab stuff from a European website. Didn't know if it was something common.no sure what you are asking..... site for Steyr or site for FMTV's? If Steyr..... you might want to ask that on a Steyr discussion board. Your probably better off having what you want fabbed for increased cab height... Looks conceptually simple; but in reality may end up very complex. (will the whole wire harness need to be 2" -3" longer for example... so it is not stressed???) While at it have them fab in mounts for rear half of front fender you would like to fit and get only that from a steyr vendor?
watch possible need for mod to throttle linkage too??Yea, was referring to Steyr parts, cab stuff from a European website. Didn't know if it was something common.
I'll probably fab what I need. Might be just as easy to do a 2-3" lift block on the front spring to get the extra clearance.
Thanks for the replies.
