M51clueless
- 29
- 18
- Tennessee
Have what I think is a 1968 M51 dump truck,
The power steering is not working
what I can tell you is the reservoir is full
I disconnected the supply line that goes from the pump to the steering gearbox, turned the engine over and had fluid come out ( pump is doing something)
Sometimes when I crank the truck I feel like I get a hint of it working but then back to it being locked up. It can idle all you want, can rev up the motor, no luck.
checked the steering gearbox was low on gear oil added 80w90 oil to it. No help.
So what do you recommend???
Thanks for the help
Thanks for the help
