erasedhammer
- 60
- 28
- Maryland
I was reading that the entire carrier needs to be swapped to the 4.10 and lower.
If that is so what do people recommend for new carrier to fit the 3.73 ring and pinion, I'm leaning between either Spicer or Yukon, unless theres a better price on another brand.
What do the costs end up being for both front and rear on average?
I hear the m1028 came with a locker in the rear and limited slip up front, how does this affect sourcing a new carrier?
This is for the Dana 60 and 70HD.
I also found a review on amazon for the motive gear D70-373 and someone said they couldn't fit the pair because it looked like it was made for a 4.56 carrier? Do they have 3.73 ring and pinions that are made for 4.56+ axles, or is that guy mistaken?
For reference, in conjunction with the gear change I will also be moving to 33" tires and nv4500. Since the nv has the granny gear and overdrive, I think the lower rear end ratio should give flexibility from around town, flat freeway cruising, and climbing mountain passes.
