well, back on this project. went to take all the intake flame heater stuff off this weekend so I can relocate it in the exhaust, just to see how and if it works, also have plans to inject propane and air up stream from the fittings to give it a bit more flame. dunno how well it'll work, or if it even will.
had to take the manifold elbow off the intake to get the injector out, decided id try to see how and if this makes a flam just sitting there. It didn't work. weird. no fuel to the pump. that's kina strange. line is hooked up, i see a bit of fuel in the line, but nothing. oh wait a sec... lets make sure the in tank pump is working, nope, blown fuse, like i see on about every other deuce I've worked on, been that way for years, stil runs fine. replaced fuse with just a 15 amp regular because all the slow blow fuses i have are 2 amp max, it works. never got to check out the flame out the elbow before it got too dark to work any more. off to store today to get more line and fittings to extend the lines out long enough to reach to the exhaust stack. i think ill plumb it into the stock pipe first just to see how and if it works before i go drilling and welding bungs into the 5 inch stack
anyone know right off hand the thread on the injector? the spark plug one i know is 18mm. the other side seems to be 20 mm 1.5?
