spankybear
- 911
- 93
- WA
So I got the truck up and running after worked through a starting issue. I can select Drive, Revere , and the truck will move. I can select first (1) when the truck is sitting you can feel the trans shift from 2 to 1. I can also select mode.
The problem is when I start out and speeding up to the point where I think it should shift the "select" side numbers goes dark but the "monitor" side stays on 2. At this point the touch pad is not responsive. The truck is still driveable but stuck in 2nd gear. I was thinking that maybe the TCM isn't getting a speed sensor input but my speedo seem to work fine and smooth (well to 10 MPHish)
Anybody have any ideas? I have had this dash apart doing body work and kept the TCM in the garage.
