Blocking off engine oil cooler lines on 6.2 Humvee engine
Hummermark
31
London uk
Hi want to test run a 6.2 Humvee diesel can you just cap the flow and return connections on the engine or do you have to loop them?
The engine is not currently in the Humvee.
On the 6.5 are the 1/4 square female drive block drain plugs still under the engine mounts? Not that useful if you want to drain block when engine in Humvee!
