tguinn
- 114
- 33
- savannah,MO
I have a D turbo in my Deuce currently, i feel like it has too much play in the shaft, (feels like 1/16"), will a C turbo work till I rebuild the D turbo?
Side to side or in-out play?I have a D turbo in my Deuce currently, i feel like it has too much play in the shaft, (feels like 1/16"), will a C turbo work till I rebuild the D turbo?
It was a dry testIs that a dry or wet test? Meaning, have you ran the engine prior to checking play?
I ask because It is normal on most all turbos to have a little extra play after oil has drained away
Yes, made that switch over the winter, along with several other changes. TimDo you have the anti drainback oil filters on your truck. If not then sometimes in the first 90 seconds of engine run you will hear the turbo stop screaming when it finally gets lube oil. All lube oil drains to pan on shutdown as per design.
